Cambium Community Forum
Official Cambium Forum, Moderated by Cambium Technical Staff
It is currently Thu Oct 02, 2014 9:26 am
Post new topic Reply to topic  [ 9 posts ]
Author Message
PostPosted: Wed Aug 03, 2005 12:30 pm
Offline
Power user
hello all,
i'll use a 5.2 ghz devices to connect 2 places.
right now the computers run with 192.168.1.X ip addresses. what's the configuration that i should use on the AP, the SM and on the computers so i can work with the canopy devices?
best regards
Top
 Profile Send private message
 Post subject:
PostPosted: Wed Aug 03, 2005 12:53 pm
Offline
Power user
1) Assign them addresses within the same IP block (i.e. 192.168.1.x) and you will be able to manage them
2) Add a secondary address to your workstation in the default IP block (i.e. 169.254.1.x).
Assuming multiple computers in the 192.168.1.x IP block and you want to reduce the risks of somebody other than yourself accessing the radios, I’d opt for #2 (e.g. assign the AP 169.254.1.10 and the SM 169.254.1.11 and give your workstation a secondary address of 169.254.1.5)
Top
 Post subject:
PostPosted: Wed Aug 03, 2005 2:16 pm
Offline
WISP Pro
i would suggest using something other than the 169.254 subnet their is lots of gear using this same with the 192.168.x.x
i would change the sm's and ap's to a 10.x.x.x
in our particular case we have assigned the 10.0.x.x for our ap's and the 10.1.x.x for the sm's
Top
 Post subject: same issue
PostPosted: Wed Aug 03, 2005 11:14 pm
Offline
Power user
i understand that the AP and the SM works as a wifi network card and that i'm using the ether port of the computer, is this correct? so i'll only have one IP address for the Pc and one for the AP and one for the SM.
with this scheme, how would you use the ip addresses?
i.e.
Pc1 = 192.168.1.100
Pc2 = 192.168.1.105
AP = 192.168.1.1
SM = 192.168.1.5
taking as an example the 192.168.x.x subnet
this way they can communicate, both Pc's and the radios being inthe same subnet. am i correct with this?
'cause i read the system user guide and there it shows 2 ip addresses for the AP in 2 different subnets. and now that i read for the second time what you wrote, is this a right configuration?
Pc1 = 192.168.1.100
Pc2 = 192.168.1.105
AP = 169.254.1.10 / 192.168.1.1 (this is the 2nd ip addr of the AP)
SM = 169.254.1.11
i believe that after reading a little bit more the manual this last configuration is the one to use, right?
Top
 Post subject:
PostPosted: Thu Aug 04, 2005 6:03 am
Offline
WISP Operator
Wrong. The LAN2 network configured on the AP is the "RF Private Interface". This network is only used by the AP to communicate with its SMs; the default is 192.168.101.1. Test it out like this:
TELNET from your PC to the AP.
LOGIN to the AP with "root" and your configured password.
TELNET from the AP to the SM using 192.168.101.2, where ".2" is the SM's SESSION ID.
LOGIN to the SM with "root".
RESET the SM as a test, if you want.
or...
EXIT back to the AP.
EXIT back to your PC.
You cannot communicate from your PC directly to either the AP or SM using the AP's LAN2 interface.
Top
PostPosted: Thu Aug 04, 2005 2:29 pm
Offline
Power user
ok, i get what you say...
where i'm lost it's in the ip addresses on my pc and the lan1 interface of the AP. they should be on the same subnet right?
then how the client communicate with the SM?
can you please write a scenario of IP addresses for 2 Pc's and a AP and a SM? let's say there's no router on this scenario...
Pc1 =
AP =
SM =
PC2 =
thanks
Top
 Post subject:
PostPosted: Thu Aug 04, 2005 6:44 pm
Offline
Networking Guru
The easiest way to explain it is to say that any and all Canopy infrastructure does not have to be on the same subnet as your computer IP addresses to function properly. Let me try to give an example.
Assume a network with:
(1) Access Point
(2) Subscriber Modules
You could do the following and the network would function:
Access Point LAN-1 IP: 192.168.1.100/24
SM #1 LAN-1 IP: 10.11.12.13/25
SM #2 LAN-1 IP: 169.254.107.99/30
Customer's IP connected to SM #1 - 10.100.1.5/24
Customer's IP connected to SM #2 - 10.100.1.6/24
The customer's IP addresses would obviously have to match up with however you have your network designed. But, the point is that the Canopy infrastructure can be on completely different subnets and they will still perform their duties, that is forwarding packets based on destination MAC address just like switches do. I like to think of each piece of Canopy equipment as a single port on a switch with a MAC address table that is capable of storing 4,096 MAC addresses.
Obviously in practice you should never do anything like this example I just gave, but I did it this way to illustrate my point. There are some other assumptions too, like NAT not being enabled on the SM's in this demo network, etc.
Does this help at all?
Top
 Post subject:
PostPosted: Fri Aug 05, 2005 9:23 am
Offline
WISP Operator
This repeats much of Msmith’s post…
The simplest, but not necessarily the best, option would be to assign all host IP addresses – router, AP(LAN1), SMs, and PCs – in the same subnet. For example, the router could be 192.168.0.1, and each other host would be given an address of 192.168.0.x, a mask of 255.255.255.0 (24 bits, or “/24”), and a default gateway of 192.168.0.1. The PCs could have their addresses assigned by a DHCP server, but the AP and SMs would need static addresses outside the range assigned by DHCP. In this configuration every host can talk to every other host; every PC can ping, telnet, or browse to the AP and all SMs.
The customer’s PC, however, does not need to access the IP address of its SM to be able to get to the Internet via the AP and router. The customer’s PC only needs to get to the address of the router, not the SM and AP. If you want the customer to be able to access their local SM’s web pages, so you can step them through the diagnosis of a problem, then the above configuration might be appropriate. In this case, however, make sure every Canopy SM’s password is different; you don’t want one customer to access another customer’s SM.
What many ISPs do, and what other forum members have suggested in this thread and others, is this: You must assign customers’ PCs to the same subnet as the outbound router – 192.168.0.x to 192.168.0.1 as above – but assign your Canopy units to a different IP network, like 10.99.x.x (or 192.168.201.x or 172.19.123.x or whatever). You’ll also need to assign one of these 10.99.x.x “management” addresses to a PC in your office to access the Canopy units. Your Ethernet and Canopy networks then carry traffic for two separate IP networks; Ethernet switches and Canopy units (when NAT is disabled) operate at ISO layer-2, IP is layer-3; there is no conflict.
A Canopy network is just a big, wide-area Ethernet switch. If you attached four PCs to a single Ethernet hub or switch, assigned the mask 255.255.255.0 and the following addresses to the PCs:
192.168.44.18
192.168.55.27
192.168.44.105
192.168.55.222
The two 192.168.44.x PCs could ping each other, the two 192.168.55.x PCs could ping each other. The 192.168.44.x PCs, however, could not ping the 192.168.55.x PCs. A Canopy network works the same way.
If you’re new to both Canopy and IP networking, your Canopy network is small, and you may be imposing on your customers’ patience and typing skills to solve problems, you might want to stick with the first configuration above. When you become more comfortable with what works and what doesn’t, but certainly before your Canopy network grows to more than 50 APs and SMs, design a new IP addressing structure and switch everything over.
Top
PostPosted: Fri Aug 05, 2005 11:09 am
Offline
Power user
i'm new at Canopy...
and i totally understand the theory behind ip networking. i've used ip networking before. i guess i was confused with the way Canopy works.
what i wanted to do is to understand how to configure them before deploy the network. i'll do some test now and learn more.
thanks a lot guys!!
Top
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
[ Time : 0.073s | 12 Queries | GZIP : Off ]
